TwinTurbo.NET: Nissan 300ZX forum - No safety boost solenoids. No codes. New det sensor (n/m)
ThisIsSparTTa
on December 09, 2013 at 8:19 AM
Re: Is my rebuild borked? Ideas, please
posted by WazTTed
on December 08, 2013 at 02:40 PM
ThisIsSparTTa
21:36:19 12/05/13
Confirm your timing belt is set correctly
ttsmokin
22:11:19 12/05/13
Can I run compression test while working on timing belt?
ThisIsSparTTa
07:55:15 12/06/13
Yeah you can
-Grimm-
09:00:07 12/06/13
If you are doing a compression test only, leave the cas
Krazyd27(Houston)
10:48:24 12/06/13
now would be a good time for a leak down test (n/m)
aliaZ
22:19:37 12/06/13
MaxxAction
16:02:07 12/07/13
WOT, charged battery, no plugs in. Could be my tester? (n/m)
ThisIsSparTTa
08:35:25 12/08/13
that isn't right
aliaZ
17:42:58 12/08/13
Re: that isn't right
MaxxAction
08:49:59 12/09/13
FWIW
aliaZ
12:53:46 12/09/13
Kyle's builds are supposed to give you between 120-140 psi
Stanky
21:34:41 12/07/13
I agree with ttsmokin, count the timing belt teeth
ZaXxon
04:27:09 12/08/13
WazTTed
14:40:21 12/08/13
No safety boost solenoids. No codes. New det sensor (n/m) -
ThisIsSparTTa
08:19:49 12/09/13
coreymbassett
07:57:11 12/10/13
It wasn't the 'hard break in'
ThisIsSparTTa
12:12:27 12/10/13
Re: It wasn't the 'hard break in'
MaxxAction
10:22:26 12/11/13
I'm not sure of any 'best' break in practice
-Grimm-
10:35:04 12/11/13
10W-30 Dino, Other work I did...
ThisIsSparTTa
11:39:33 12/12/13
That's the hard break-in. Would have been ideal, but...
ThisIsSparTTa
11:40:55 12/12/13
'Hard Break In' doesn't have to occur at a distinct point
-Grimm-
12:41:12 12/12/13
Some Updates
ThisIsSparTTa
08:52:44 01/02/14
